I have a 93 250, intercooled, and I'm looking for tome hp/tq. It's bone stock, and all I've done is turn the pump up and straight pipe. I'm new to the first gen world and excited to start my build. Let me start with this, I turned the pump up a lot. When i get the pedal over 3/4 travel, it starts to bog down and won't wrap out in the high rpms. Yesterday I pulled a medium size tractor on a flat bed trailer and it didn't want to pull worth a ****. I'm guessing it's because I have it turned up too much? Running empty, i can leave a stoplight and spin tired for 10 yards and roll coal like a frat boy in a powerjoke. But when I reach full throttle it doesn't go into high rpms and I cant pull well.
So correct me if I'm wrong, but I think more boost is the solution? I've been looking at the HX35, but I'm not satisfied with the size of it. I almost bought a HY35W but called around and came to the conclusion that it would be too much of a ***** to get put on. From what I've read after hours of google searches and forum scrolling, I've found the HE315CW. Who knows the details on this turbo? Is it worth it? I want to be able to have a hot running speed demon with fast spool and 30-40psi of boost, but also be able to pull every now and then. So what turbo would yall recommend? fairly easy hookup and simple to get going? What all would I have to get together to do a turbo swap(gaskets, manifolds, flanges, ect.)? thanks -Cooper
