I have a '93 160hp VE pump, 12 valve with a bad injection pump & a '98 215hp 12 valve with a burned piston. For a low buck (more time than money thing) upgrade, could I strip the 93 down to the long block and install all the 98 engine components on the 93 long block? (as in the pump, injectors, lines, turbo, etc) Would I then have a 215hp rating or is there internal differences between the 93 160hp & 98 215hp long blocks?
Thanks in advance for your replies.
