94-01 steering wander guys.....
With all the post's lately talking about horrible dodge steering, I thought I'd really get you guys to focus on the caster issue, and try to get everone to understand it better. Caster's importance get's mentioned very often, but usually in the middle of a thread, and does not get noticed being how important it is... If you've tried everything, your allignment is in spec by the "so called" book, or your truck just drives all over the road, this is where you REALLY need to focus... .
Caster is a strange thing and it's main purpose is drivability. It is also the sole reason your steering returns to 100% center after turning a corner, so if your truck does not return all the way to center, there is your first clue something is wrong. Caster requirements can also be different for different trucks so if your allignment guy says you are in spec but your truck wanders all over the freeway, don't listen to him and don't pay him anymore cash, fix this yourself...
What you will essentially be doing is rotating your axle a small amount so that the weight of your truck makes the steering center itself. To do this on a Dodge you will be LENGTHENING your LOWER control arms buy rotating the cams in the axle. Mark the cams first so you can go back to where you started and for future reference. Go just a little at a time and feel whats best without going to extreme and back pedal a bit if there seems to be no progress in feel. You will be AMAZED with the new truck you have...
This is NOT a cure for worn parts and out of ballance tire's but it's my personal opinion that Dodge's factory caster "spec" is way off... .
Hope this helps some of you!!!
Don Thuren...
Don Thuren...
