I'm posting this here because it seems to be a problem with high HP trucks...
I need a way to make the T/C stay unlocked longer under normal acceleration. As it is it locks up at either 44 mph or 41 mph depending on which speedo gear I use. At that low a speed, the torque is way more than the TC clutch can take, probably due to the TV cable not being pulled far enough to increase the pressure. It's worse when pulling a trailer.
I already have the TPS slotted to the point it is barely held on by the screws. I also have the throttle linkage adjusted so there is barely enough travel to get WOT. Neither of these mods have affected the lock up point much.
I really don't want to hang something on the side of the trans to manipulate the TV or add an electronic control.
I think better placement of the linkage rod pivots would allow more travel on the bellcrank which would allow the TV and TPS signals to increase quicker before the pump lever was moved too far.
Has anyone tried changing the lever lengths on the linkage?
Is there a better way?
