94-95 trans sender
Pyrometer Mounting???
Boost Source Problems???
For those of you who want to install a trans gauge in your 94-95 auto I have a great fix. Remove the factory sender and put a 7. 5 K ohm resistor in it's place, this will tell your PCM that your trans temp is 98 degrees. You can then install your aftermarket sender in the line where your factory sensor was and no leaks.
Just a little FYI
2000 2500 long box 6 speed with everything but cab roof lights,Pyro, Boost, K&N, 4" exhaust, BD Brake, OEM nerf bars (best fit), [BOMB'D SRX700] 1 877 511-5599
[This message has been edited by Blair (edited 04-10-2001). ]
I believe it is 3/8.
