This style of transmission does not have the 4 bolts underneath the rubber boot that allow one to easily "pour from the top". [more later]
Purchased 5qts of the oil from Summit Racing using the GM part #12346190. It's an AC-Delco labeled bottle. There was another online vendor who had a lower price, but overcharged for s&h.
Drove unloaded truck 20mi. I/R thermometer reads 126*F. Using GAmes' technique, I place both pass. side wheels on ramps, tilting truck. Remove bottom PTO bolt [14mm socket fits well, despite the markings on the bolt head which suggest it's SAE]. Drain fluid. It's filthy, stinky, & nasty. Remove other PTO bolts. PTO cover remains firmly in place. Use putty knife & light hammer taps to pry off PTO cover. Use hand to scoop out what I can of the old undrained fluid. Examine exposed gears [They look alright, but I'm no specialist]. The square magnet on cover has about 1/4" of crud stuck to it. [BTW, the pass. side PTO cover does not have a magnet on it ('96)]. Scrape off most of the old gasket. Wire wheel remaining. Finish with brake cleaner. Wire wheel the bolts. RTV new gasket. 30 ft-lbs reinstall. And here comes the un-fun part...
I've never taken the shifter off any manual transmission. Supposedly all you need for this one is two screwdrivers pressing down & turning CCW. It's the installation that has been described as a 'pia' in previous posts here. I need to use the truck as soon as I'm done. Gonna go for the side pour after using a 3/8" hex key to remove the fill plug. Have a small 3" diameter funnel. For a dollar I purchased a flexible vinyl hose which I trimmed to 5" length. **** <-- This method sucks. I can't see how much I'm pouring into the funnel, and my 'liquid gold' overflows onto myself [at least it's clean (thick & clear)] & the driveway. Two thirds of the way through the first bottle I stop to rethink this process. I watch money dripping away from me in the form of a sizable GL-4 puddle on the driveway.
These 1qt bottles are tall & skinny. They have a pointed spout that requires a utility knife to cut open, much like a tube of RTV/caulk. They are also flexible.
New Technique: Squeeze that liquid gold right on in there! This works well for about 3/4 of the oil in the bottle [Bottle is too tall; exhaust pipe interferes with getting a downward angle]. It makes lots & lots of farting noises that your kids will laugh at if they happen to be nearby, yet it does not spill! I am pleased. Take another bottle and squeeze it in there. Combine the leftovers into a bottle & keep squeezing! Works like a charm, and fairly quick too. 30 ft-lbs on the fill plug. Done.
For those of us with older NV4500's who are also without special tool 6783 and special tool 6870, Remover/Installer Gear Shift Lever and Remover/Installer Shift Lever Stub Shaft (respectively), the bottle-squeeze method allowed me to put about 4 1/4 qts of fresh OEM transmission fluid with relative ease. I'll work on "pouring from the top" another day, and then I'll add my extra gear oil.
