94-98.5 parts into a 89-93 question
Engine sawp.
Adjust IDLE
Good Morining All,
Can someone tell me if the brake and clutch pedal assy from a 94 will fit into a 93?
Are they completely different? can it be swapped with little to no modifications?
Brian
I can tell you that stud on the brake peddle for the power booster is smaller on a 2nd gen vs a 1st gen, but the push rods are the same length, but if you are going that far I would install the 2nd gen hydro booster and master cylinder as well.
I have heard the 2nd gen pedals are longer than 1st gen's are. but I have not had a set of each side by side to confirm it.
All that I can tell you for sure is that the 2nd gen. Heavy Duty Hydraulics from South Bend will work. That is what I have in my '93.
Bob
Agreed. I also have the SBC HD goodies in both of my trucks. Irony is, the HD goodies are actually stock gen 1 Chrysler components. LOL Minus the orientation of the slave, it is no wonder why they fit. LOL
Yes. I have heard the same. Also not sure if the top bushing the rod slides through that the entire pedal pivots on is the right width.
I heard both year ranges use the same size rod and upper bushings.
I'll try to find a set of 2nd gen pedals to look at. I will have a set of 1st gen pedals after this weekend.
