HEMI®Dart
Noticed this summer I was down 7-8 Lbs of boost getting on the entrance ramp to the highway in valet mode. EGT's a little low @ highway speeds.
Hooked up boost leak tester. Found a blown-out gasket on the Banks Twin-Ram air horn. Repaired. Still down on boost. Hook up boost leak tester again. Charged it to 15 PSI. NO leaks anywhere. Replace gauge.
Replace Fuel Filter. Check pre-filter/ Strainer. Fine.
Hook up fuel pressure pressure guage. 18-20 PSI idle (acceptable) than @ 2000 RPM no-load got 30 PSI to start, then dropped to 25-20-15.
Install new OFV020 from Tork Tek. 25 PSI idle, same story @ rated speed.
Bought a new lift pump from Geno's.
McMaster Carr p/n's
93675A265 ASTM A193 Grade B7 Alloy Steel Fully Thread Stud, M8 Size, 50 mm Length, 1. 25 mm Pitch $4. 88 each
94920A500 Black Class 8 Steel Serrated-Flange Hex Locknut, M8 Size, 1. 25mm Pitch, 13mm Width, 7mm Overall Height. $11. 43 per pack of 25.
Note the 13mm head size & the . 706 flange vs. 10mm . 650 flange OEM bolts. These fit perfect and I shouldn't have to double-nut them. No interference w/ the pump body.
I wish I hadn't sprung for the gaskets from the dealer, as the Cummins (China) gaskets were identical to the Dodge dealers.
McMaster Carr p/n's
