Engine/Transmission (1994 - 1998) 94 Automatic transmission...wrong oil
Engine/Transmission (1998.5 - 2002) common rail swap
2nd Gen Non-Engine/Transmission 3/4 to 1 ton conversion
Yep, I am a bone head! I didn't read the label and poured about 10 oz of Lucas Oil Stabilizer down the tube before I can to my senses and re-read the label that now seemed to be in giant font MANUAL TRANSMISSION USE!!!!
anyway, I plan to drain and flush tomorrow
The label stated: "Since it is pure petroleum, it can safely blend with all other automotive lubricants, even synthetics, ATF and mineral oil. It keeps old engines alive and new engines new. "
Am I freaking correctly or can I let this slide until the next filter/fluid change?
thanks All
The label states it safely blends with ATF?
I'd still call lucas tomorrow and ask. But it looks ok. (I'm not a lucas fan)
I am not a fan of most "Mechanic in a can" products. I too would call them up just to be on the safe side. I would "think" you would be ok though.
Change the oil ASAP, 10 oz in 4 gal ain't much. there was a reason you put it in, in the 1st place. if it fails you can blame it on the lukcas. who knows it mite help.
