Have tolerated directional air flow control of heat or ac that has a mind of its own. In other words the rotary selection of air flow will at times be directly at you another time it may be up on windscreen, etc. AC and Heat controls and fan speeds work fine. So I presume if vacuum is ok at the rotary control, it would then be some downline failure either mechanical or vacuum at a flap solenoid. Vacuum must be working generally as brakes work fine, etc. I could not seem to phrase my "search" inquiry to nail it so must post this "new" (?) thread.
I will add that we have the dash partly removed but hesitate to do more. Cannot figure out what next to remove and not sure if the whole top of dash has to come out. My Haynes manual does not show enough to get at the hvac air control box and its guts. Have a complete printout of the box and all its parts. I see there are 3 solenoid actuators and expect trouble may be there. But getting there is my present roadblock.
Thanks for any replys. Larry
