My 2003 4X4 HO Dually rides much better than my previous 1996 4X4 HO Dually did. This isn't my imagination talking either, it's the longer rear main spring leaves in the 2003! The steering is superior too. Very precise. It seems like all I need to do is point in the direction I want to go, and "Big Red the Second" takes it from there! The brakes are much better too. That's a no brainer!
When leaving a stop sign or light, I know the 2003 gets away quicker. When hitting 55 m. p. h. , I look in the rear view mirror and the stop sign or light is a lot closer than when I reached 55 in the '96. It takes a while to go through the gears, but when I get into fifth and sixth, "WE GONE!!" I can really feel the 305 horses when running in overdrive at 65 m. p. h. , and then laying the pedal to the metal. Although I haven't pulled any heavy loads yet, other posts have contained testimony from the heavy haulers. I've sure not seen any complaints from those guys!
Also, the frame is stronger, the axles are of higher capacity, the anti-spin rear axle actually works (as compared to the previous Dana limited-slip), the transfer case is heavier, there is more room in the Quad Cab, there are side-curtain air bags, etc-etc-etc. Hey, it looks good too!!!! Ford will probably try to copy it like they did the 1994 Dodge model.
In summation Brothers and Sisters, if there is a better truck than the 2003 Dodge CTD, I know it's being driven on streets paved with GOLD!!!!
