I have a 95 dodge 5. 9 cummins. I wanted to adjust the fuel plate and had to take the AFC housing off. To do that i have to remove the tamper proof screw, to do that i had to take a couple of the lines from the injection pump off.
I put it all back together and it ran rough. I cracked the lines while the truck was running and found it was coming from # 6 injector. I blew the lines out and cleaned the injector( i found little pieces of paint flakes in the injector from undoing the lines). After that it ran a little better but was still rough. I took all the injectors out and had them checked and they said they were fine. So if it is not the injectors what could it be. Could it be the injection pump or what?
