I have a 95 2500 Ram truck and I stopped at a local store to make a purchase and after I got in the truck started the engine and turned the lights on I noticed I didn't have dash lights or tail lights. I checked the fuse and it was blown , replaced fuse turned lights on blowed a fuse again. I kept tinkering around trying to find the problem. With the fuse out I could pull the light switch part way out between off and on and the lights would burn. Got the truck home (without getting caught) and next day I put another fuse in and the lights worked fine until Last night and now it is doing the same thing. I remember a while back I read a post about my model truck having problems with the switch going bad. I did a search but I can't find the post about the light switch. Oh by the way, when the light switch is pulled half way out the parking lights are dimmer. Does this sound like a bad switch or do I have another problem?
________________________________________________________________
95 2500 Ram 5 spd. #8plate,timing151/2 , AFE air filter,lighted visor, running boards,boost,egt, engine temp. & fuel pressure gauges. rose wood dash kit,cb radio, 10cd changer 5th. wheel hitch,sprayed bed liner. towing mirrows,running lights,tinted windows,tdr grill badge
