Details here: TDR Privileges
A friends '95 radio has started to act up in that it is intermittent in working. Is there two hot wires to that radio? Now it doesn't work at all. Has anyone had any simular problems? Chris
I didn't have a radio for the whole ride out to and back from Muncie. I just had the 5" single stack to listen to...
I took the OEM radio out of my brother's '97(?) Jeep and it was a bolt-in affair... it has worked fine since then.
The radios were 99. 999% the same... . the only thing that was different was how the plugs on the back were aligned... . but everything plugged in as if it was meant to and worked awesome.
I had two factory radios in my 96 do the same thing. First was covered under warranty & second was replaced with a much better sounding aftermarket unit.
