96 12v Loses power or dies at 1/2 tank
Electronic Throttle Control Light Activated
6.4 HEMI 0 psi oil pressure in Black Hills
Hey guys little bit of an emergency, my truck runs fine all day until about half a tank then it loses power or dies while driving if I coast in neutral. Once it dies I can usually crank it right back up and it’ll run, if it doesn’t then I have to wait like 10-15 minutes. if I’m not driving it for a while and it sits at home a couple of days it fires right up and it’s fine.
I already have Installed new injection pump, lift pump, Fuel filters and cleaned injectors. Need INSIGHT ON WHAT NEXT
Have you checked the fuel lines from front to back, including the module on the tank ?. I have read about pinholes etc. on the line at the module where the hose connects. Behind/between the tank and frame is a hot spot also.
I’ve replaced all fuel lines with steel braided hoses. I haven’t checked module will do that mow
If it turns out to be the module, I changed mine out with a Vulcan non pump module from genosgarage. Be sure to order the gasket sold seperately.
