It is way past time to fix, once and for all, the front suspension on my '96 2500 4x4. I can't afford to keep feeding it new $200 tires. I can't stand driving the truck anymore, either, and it's our best and newest vehicle.
My plan, put together from spending many hours reading old posts and checking out various aftermarket "cures" is as follows but leaves plenty of unanswered questions such as which name-brand ball joints and tie rod ends, etc. to use. (spicer/napa, moog, etc. )
I would greatly appreciate opinions (maybe even a consensus?) as to how to fix my truck right the first time.
My plan so far:
1) Solid Steel brand adjustable track bar and mounting kits
2) Solid Steel steering stabilizer/power steering box support kit
3) Solid Steel adjustable lower control arms
4) Upgrade inverted Y components to 98/99 crossover steering components (Moog or other brand?) (Thanks Mark for the great photos and info on all of your modifications!)
5)David Bazley's column bushing kit
This leaves plenty of items yet to cover:
6) Ball joints (and all other steering components): Who makes the absolute best?? (moog, spicer, etc. )
7) Polyurethane upper control arm bushings? Or maybe aftermarket upper control arms that I don't know about?
8) Polyurethane sway bar bushings?
9) Shocks?? Currently Rancho RS5000.
10) Steering stabilizer?
11) Maybe 2" leveling kit? (which type/brand?)
12) Do shock towers need replaced or upgraded?
13) Alignment specifications?
14) Anything I've overlooked?
I need my truck daily and I use it to plow snow in the winter with a heavy Boss V (not much commercially, but I do take care of a few rural widow ladies and elderly folks, too). I want to "fix it right and fix it once".
I would really appreciate any guidance on the items I need to buy, brand names to use, things I have overlooked, or better components to use. i need to get to buying the components asap and get everything ready beforehand to minimize downtime. I wish I could say "cost is no object", but it most definitely is. On the other hand, I don't want to cut corners or redo things later.
Thanks for any guidance!
My plan so far:
