Bob is right on. It's a quick test and even if you can not measure the output current, your dash voltlmeter should go up significantly when the field sees full battery voltage. This will establish that the alternator is working OK.
Also, is your tach working? Loss of the engine speed sensor inhibits the computer from demanding a charge.
Rog
