Engine/Transmission (1994 - 1998) 96 oil leak
2nd Gen Non-Engine/Transmission Tow Mirrors
it appears that my 96 is leaking oil right behind my injection pump. at least thats were it appears to be wet. is there a seal in there or something? how difficult is it to fix?
If it's behind the IP, it could be the oil supply line to the pump. Give it a check. If not, it's probably the vacuum pump seals just below the IP.
Scott
The RED shows where the vacuum pump leaks. The oil supply line for the IP is on the back side of the IP between it and the head.
Scott
