Has anyone accomplished or thought about converting from the pressed on rotor design to the later model slip on design. Will the later hub/bearing assembly bolt into the earlier knuckle? I am getting ready to do the brakes for the 1st time and am not looking forward to pulling the bearings and pressing out and reinstalling the studs. It would be so much easier to use the later design. If the bearing doesn't bolt in will the later knuckle fit the earlier housing, may be a good time to do the ball joints also.
Thoughts, Ideas???
Thoughts, Ideas???
