Engine/Transmission (1994 - 1998) 97 just died
Engine/Transmission (1998.5 - 2002) Boost Tube
Engine/Transmission (1994 - 1998) EGT's??
Without warning my truck just lost power, smoked and died. It chugged long enough for me to get it off the road. I could smell something burning (plastic or rubber) I looked under the hood and everything seemed OK. The smell was strongest in the cab. The truck turns over, but the plug light does not come on when I turn the ignition on. Any thoughts on what happened?
Could be the shutdown solenoid. I have had then die before. . But never had any smoke.
Wire it up and see if it starts.
I know just enough to get me in trouble. Is the shutdown selenoid one of those on the drivers side fender? Just wire the terminals together and bypass it? since the smell was stronger in the cab than under the hood, I plan to check the fuse box in the morning and see if it looks melted.
