Hello to all on the TDR. As you've probably noticed this is my very first post so I'm hoping not to mess it up too badly.
The lift pump on my '97 was leaking at the bottomside of the plunger so it's time to change it out ( the truck has 86,000 miles). To access the pump I removed the fuel filter cannister (installed new filter). Installing the new pump went fairly well once I realized life would be easier if I release tension on the lines (at the top of the cannister housing) that extend to the pump and pre-heater.
Before starting the truck I gave the plunger 20 or so pumps. No luck, the truck would not start. I pulled the cannister off and filled it with fuel since there was little in it. I thought pumping the plunger would have filled the cannister since that seems to have worked in the past. I eventually was successful in starting it but oh did it smoke and run rough. It ran for about a minute then stalled. I cranked it over for a while and it would not restart. I depressed the plunger a bunch of times again and still nothing. The cannister came off again and sure enough it was low. I filled it up and eventually the truck started . Again there was lots of smoke and the truck ran very rough, however it did smooth out some but not completely. This time it ran for about two minutes then stalled. I cranked it over a number of times but no luck, it won't start.
This may help so I figured I would add that the truck is completely stock and I have replaced the 5/16" fuel (return?) line. Any help would be greatly apprecited. TIA.
