Engine/Transmission (1994 - 1998) 97 throttle bellcrank replacement
Engine/Transmission (1994 - 1998) Starter Contact
I am looking for a replacement pin or the entire bellcrank assembly on a 97.
The center pin that the bellcrank rides on has worn pass the bushings and has worn out.
Does anyone know where I might find a new pin or bellcrank assembly?
I went through this recently and the pin is part of the bellcrank assembly, kinda spendy for the assembly from Chrysler.
A better option is go for Dodge part #CANZ9700. It's a kit that contains a throttle cable, new pins, springs and ball socket ends for the linkage. I can't recall the price but it was way cheaper than buying the whole bellcrank assembly.
BTW: Anyone needing a linkage assembly ( the rod with the ball sockets on the ends ) the part number for that is 05011959AB and no it's not listed in their parts books.
