PToombs
I know track bar conversions have been well covered, but I have been looking for 30-40 minutes and haven't seen what I was looking for. What is the better way to go for ends, the poly bushing, or the heim joint type ball end? I have a Lukes Link on my track bar now but it is about whipped. I've adjusted it several times, but since I live where the State policy is to put down as much salt as snow that fell, it's a several hour process to clean, heat, disassemble, clean, lube and reinstall and adjust the link. I can get the Spohn conversion for about $380 but it has the ball ends and I don't know how well they will hold up.
I was also looking at just getting a conversion bracket from someone like Synergy, and getting a used 3rd gen bar from a junkyard and putting new bushings in it. Then I got wondering, will the bracket work with a regular bar, or is it designed to only fit their conversion track bar?
I want to get the best bang for my bucks as I don't have a lot available at this time but it needs to be done. The truck has a leveling kit, DSS bracket, and the Link on the trackbar. The summer tires aren't huge, 265/70-17's, and the winter tires are 235/85-16's, which end up being the same height.
