My truck is a 2001 Dodge Ram 2500 with the 24v Cummins. Last summer I began to experience intermittent problems with my cruise control. This truck is very clean, never been driven up north in the salt. Everything but the cruise control works flawlessly.
When the problem began, it was random:
I would turn the cruise control on.
Set the speed
It would hold the speed perfectly for 5 to N minutes
Sometimes I would have no issues the whole trip.
Other times it would suddenly cut out, turn itself off and throw a P1595 Trouble code. (Cruise control solenoid circuit. Only way to get cruise control back on, was to turn the truck off and restart the engine.
This is not a vacuum issue but an electrical one, (although I did double check all the vacuum lines, etc)
Since I first started to try to track this down, the problem has grown to the point where the cruise control does not work at all.
At this time, if I attempt to even turn on the cruise control, the cruise light flickers and goes out or does not come on at all.
Here is what I have tried up to this point:
Is there anything else I need to check or something that I have missed? I am at a loss.
Set the speed
- Checked and cleaned my grounds.
- inspected wiring harness
- replaced brake pedal switch.
- Replaced the clock spring
- Purchased a snapon solus pro and then performed the following diagnostic procedure you can find at moparman1973.com: https://mopar1973man.com/cummins/ar...4/p1595-speed-control-solenoid-circuits-r128/
- From that procedure, I validated that wiring from the servo to the PCM was good, wiring to brake pedal switch was good.
- 5 I even removed the cruise control switches, disassembled, cleaned and tested them.
- 6 I have a spare PCM and a spare speed control servo, tried swapping the server and then the PCM, to no avail.
