I have a 98. 5 dodge ram 2500 with the 24 valve, auto transmission 4x4.
All data gathered while engine was running,
I am having an issue with the alternator not charging, the problem came up when I was driving to town the other day and noticed that the voltmeter was reading below normal, when I got to my shop I threw a voltmeter on and I was getting 12V or less. I was also having issues with the transmission, it felt as if it were stuck in 3rd gear.
I replaced the alternator with no change, truck still not charging.
I tested the to see if I had voltage at the two small terminals on the alternator, I was not getting any readings, I tried connecting each terminal to a 12V voltage and I did not get any increase in the output which hovered around 12. 0-12. 5V
where do I go from here? is there an possible ECM issue and I need to convert to external regulated? is there a fuse that could have blown?
Truck is dead in the water
Please note: if you respond to "just search TDR there are lots of post about this" please provide a link(s) to said resources. I have searched already and now I am asking for help.
Thanks in advance
Thanks in advance
