I have a 98. 5 3500 24v dully. In Dec. 08 I changed the fuel pump. I replaced the injector pump at the end of Feb. 09. This Jan. I changed both fenders on the truck. About 3 days after I got my truck back it ran great.
I stopped at a store, when I tried to start my truck it would not start. It started after I sprayed it and jumped it off with an f350. The check eng. light came on when I was driving home.
The next day it started right up. After driving for about one hour I parked for two hours, when I tried to start the truck all it would do is turn over. I tried to jump it off and spraying it, nothing.
I had a friend of a friend who’s a mechanic for a local dodge dealership tests it and he said that it was the injector pump. (There was a break between the ECU and the Elect. . Module. I ask him if changing the fenders and discontenting & reinstalling the elect. Fuses and hardware on the fender could cause this problem, he advised it couldn’t.
I tried to jump it off one more time to put my truck on a trailer. It started right up. It was running great. We let it run for about 15 minutes. When I turned on the head lights the truck stopped running like I turned off the key. We restarted the truck it was running great. Turned on the headlight and it stopped again. Would not start after that. I had to get a wrecker to haul the truck
I sent the Injector pump back to Pensacola Fuel Injector, as it was just under a year that I had bought it. They advised me that they sent it to Bosh to have it tested. I was informed that injector pumped check out ok. I ask the guy on the phone if changing my fenders could be the problem. He advised me it could be that a ground wire it’s connected or a hot wire isn’t connected tight enough.
He advised me that it could indeed be what is causing my problems. The mechanic said that he will put it back on and see what happens. But that everything points to the injector pump.
Any help would be appreciated.
Thanks, Raymond
Thanks, Raymond
