I replaced the instrument cluster with another used one, everything worked except the tach. I removed the cluster and cleaned electrical contacts on the back and also the bus connector near the brake pedal. Both batteries were disconnected while doing this.
After reassembly the only power is to the dome light and the four-way flasher (front lamps only). There is no power to anything else, no start, no radio, no heater fan...nothing. Anyone have any ideas where to check or what to replace if needed?
Motor Schroder
Motor Schroder
