Hey, new to 24 valves here. I picked up a 98. 5 24 valve with 236,000 km. The VP44 has a 'remanufactured' tag on top. The truck starts good and runs good when first started. Runs smooth up to 3000 rpm, but once truck has run a few minutes it starts to miss bad and smoke white past about 1800rpm. If i put the pedal down it wont rev past about 2400. (this is all being checked under no load in the shop) It still starts good and idles nice when warm. I checked supply pressure by hooking a gauge to the fuel filter canister (take out a 1/4" npt plug) and the truck is running about 5-7psi, and it drops down a bit when revving up. It has the lift pump in the tank. I thought the problem was fuel pressure, but seems like someting else since it runs ok when cold. Anything electronic that could cause the problem? Not sure if there is a way to reset computer. Just hoping the VP isnt going bad. Thanks in advance for any help.
