2nd Gen Non-Engine/Transmission 98 Bad brakes
Engine/Transmission (1994 - 1998) Relay amp ratings
I have a brake problem 1998 12v I rebuilt the rear useing GM
1998 rear wheel cylindres 1. 0625 the dodge wheel cylinders were smaller
. 875 did a lot of good for the rear. did the front with HD dodge parts
resluts were Not Good at all
I heard about using GM calapers from a 4X4 3500
the calaper will fit the dodge spindle using 3500 break pad
more pad surface
but their is is a 1/4 . 250 gap between the rotor & the pad
rotor is not as wide as the 3500
Has any one used this set up & how did it work out
did you use a spacer
& what GM parts did you use.
Larry I did the fronts on my '96 using slotted rotors and Performance Friction brake pads. Really helped. Didn't break the bank either. I spent some extra $$ and bought blueprinted calipers from EGR, they greatly reduce the chance of binding up & pulling.
You should read Rhonda's writeup on the Home Page of TDR about ART brakes . . .
Vaughn
I would like to hear about the GM calipers as well.
Are you saying that the GM calipers will not squeeze the pads in enough to take up the 1/4in difference?
I am researching GM brakes on a 1998 2500 2x2
dodge 12V
looks like the 1998 3500 GM 3500 duel rear wheel 4X4 ,front calaper would work with pads the problem the GM rotor is 1/4
in. thicker would leave a 1/4 in. gap I think the calaper would make up for the gap. do not know if the master cylinder would have the volum needed may have a low pedal. Has any one used GM brake parts what model & Parts did you use
with out any mods. how was the out come.
I would like to use standard GM parts
May have machine shop make a 1/4 inch spacer if need be. it looks like it will work.
I know about the high performance brakes
& high Friction pads. I would like to use GM if possable
