took off the cluster and cleaned the two harness on the back w contact cleaner but they looks very good... w the cluster in position sometimes it illuminate and sometimes not; if I move it a bit it illuminate and function good for a while... maybe its a contact problem on its back... pins and harness looks perfect. . I've noticed, w the engine off, that when I turn on the lights, and cluster not illuminate(both LH and RH turn signal lights on and flashing intermittently) I hear a bad noise from thre engine bay... like a relay that engage and disengaged continuosly, its the fuel system relay under the fuse box in the engine bay; and even the "valves"wires/connection bolted to the inner LF fender, under the left battery, I think its the stuff for the heater grid(cables goes onto it)... but I dont know what that concern w cluster illumination...
I need help, thanks
rob
