99 3/4 4x4 A/t Mileage 14-15 Is This Normal?
Advice On transmission Shop
Valve Adj.
MY BROTHER HAS A 99 3/4 4X4 WITH LIFT KIT
AND 285 OR 315'S OR ABOUT THAT SIZE TIRES
AND 4. 11 GEARS , IS 14-15 EMPTY NORMAL?
ALSO HE WANTS POWER BUT NOT LOWER MPG
I TOLD HIM TO JUST A EZ BOX
WHATS BEST AND IS THE MPG NORMAL
BILL
sounds like it's in the ballpark--now for the power thing--he's got to get this mileage thing out of his head and BOMBS away... he,he... . chris
CHRIS
CHRIS MY BROTHER FINALLY HAS THE BEST TRUCK
OR VEHICLE HES EVER HAD , HE WANTS TO PULL
RV TRAILER W/ 2 HD'S INSIDE , AT LEASE HES CONCERNED ABOUT MPG'S
HE'S STILL THINKINHG OLD GAS STUFF MORE POWER
USUALLY MEANS LESS MPG, BILL
SEE YA CV08252001 AT THE DRAGS
If he has not corrected the speedo for the bigger tires the mileage figures are going to be low and not actual.
If you take that in to consideration then 14-15 is somewhat low.
If not then it is ok because you will add 10% to 15% to your figures and that will put him right in the ballpark of normal.
Ted is correct, with 285's it calculated out to be just over 8%. That would mean that he is getting about 16. 2 mpg with 285's, and even more with larger tires.
