99 3500 DEAD AGAIN!!!!
Help on Gauges
2003 4500?
Same problem,different day. Dealer replaced engine wiring harness less than 200 miles
ago! I'm afraid to hook up 35 ft Holiday Rambler 5th wheel. Did 2001 3500 lower it's towing rates?
see 3/06/01
99-3500 4X4 AT LB grill gd lightes running boards roll cover(box)
I have the same identical truck as you and it is starting to die after it starts. Mine just died last week, service rep said it was fuel filter. I went out to start my truck yesterday and it stumbled after starting but this time stayed running. I didn't think it was the fuel filter since i only had 4,000 miles on the filter. How long have you had this problem. How does your truck act when it dies, mine starts runs about 5 seconds and then dies with no restart, turns over just fine but will not start. Ron
P. S. I'am away from my computer all day, so I will not be able to respond till tonight.
P. P. S. If anyone is haveing this problem please!!! please!!! post on this thread as there is strength in numbers.
1999, 3500, 6x6, slt, auto, 3. 54, Qd cab, ISB cummins, towing 2001 26RKSS Tahoe 5th wheel, 1999 120hp 1800 bayliner.
I believe there is a TSB that covers this, electronics ????.
Did the dealer check the fuel pressure, lift pump????
Do you have vehile theft system , option LSA. then check TSB 08-24-00
[This message has been edited by JNutter (edited 03-12-2001). ]
Moving this over to engine area; hopefully you get this straightened out. I know how annoying these problems can be. My best guess would be there's a fuel pressure problem of some kind -- either: lift pump, injection pump, air in lines.
I have a 99 3500.
The only problem I have had is the Cummins started stumbling, and the check engine light came on. The dealer (Winona Chrysler (whom I highly recommend)) went into the fault codes (which are stored when something happens) and found out the crankshaft sensor was bad. But It did not quit, but seemed to run better after the sensors were replaced. Are they going into (the cumputer??) and finding any faults with the engine stored??
'99 3500 Quadcab Laramie SLT with customized aluminum flatbed
B&D bombed with Jakebrake, firestone air bags; 3. 54 gears
5 speed,6X4, truck mirrors, trailer towing, and camper pkgs.
Ranger Cb with Messenger kicker; Amsoiled throughout. . .
2000 Peterbilt 379 with Cummins N14plus 500 hp
13 speed fuller, 70 inch Unibilt sleeper
American Class
Had the scanner on last monday and again today, service manager says no codes stored. Ron
