Installed a FASS HPFP 95glp on my 99 a month or so ago. Ran the 3/8 line to the stock fuel filter. Psi was great and could not draw it below 16psi at WOT. About a week ago I smelled Diesel fuel, check under truck and rear of front diff and starter are wet. The Fuel Heater unit on the fuel filter housing was leaking. Quess the FASS is doing it job! :-laf
Call Dodge and Cummins to source a new housing and they both come up with the same anwser. The early 24v's with the fuel filter as on my 99 cannot be bought or sourced at all any longer. Dodge and Cummins can sell a filter replacement kit which is the newer design. That kit is in the 700 dollar range. :{
Well since Dodge and Cummins drop the ball agian I decided to make something work. Called Glaicer Diesel and order the universal Fuel/Water seperator Filter Kit :
http://www.glacierdieselpower.com/product.asp?pf_id=FS1212-UK
This kit comes with all needed to add in line and a frame rail mount. I give my great Diesel Tech (Albie) a call and tell him I need his skill once agian. Once again I am very pleased and amazed at how oem he made this look.
Here are a few pics of the new setup. Not a psi below 17 now. Oo.
Also Installed new Map IAT sensor and this S&B Intake. A louder turbo and better response with this cool air instead of the bhaf turbo heat...
