2nd Gen Non-Engine/Transmission A/C clutch cycling switch changeout
My clutch was not cycling off, I tested the pressure switch and it was bad. I read the service manual and it seemed that I could change the switch with the system charged. Unscrewed the switch, took it to Dodge and purchased a new one. However, now I can't thread it back on the accumulator without the o-ring blowing out from freon pressure. I have tried several different new o-rings, lubed and unlubed. Even tried the old one. no luck. Do I have to evacuate the system to get the switch on? thanks.
I have never had to evac one yet for changing the switch... ... ... I would have your parts guy double check the swith he gave you for correct application.
Bob
thanks, but we did that. it is identical, including part number on side. In fact I had to take a red sharpie and mark the old one as "bad" because it's so easy to confuse the two of them. Once I couldn't get the new one on, I tried the old one, same thing. I'll try again in the morning. As my mechanic buddies say,"Maybe I just wasn't holding my mouth quite right!". I've tried so many times, I now will have to put some freon back in to replace what's leaked out.
