TSandner
2008, 2500, 4X4, Quad cab.
When I first start the truck the A/C compressor clutch will engage and then disengage in a short time, and will continue to cycle in this manner until I start to drive it down the road It only does this on initial startup. Once I start driving it will engage until the evaporator reaches the appropriate pressure and then it will cycle on and off as designed and cools the truck just fine. Even when I come to a stop, such as at a traffic light, it will continue to cycle and cool as designed. It only does the short cycle at initial start up. I have tried pressing the accelerator and holding a higher engine speed while parked but it does not seam to make any difference. The only thing that will get it to work correctly is starting to drive the truck. I don't need to be going very fast so I really don't think it's airflow through the condenser.
