2005 Dodge SLT It was in a flood got it up and going and everything is working now except my A/C. The truck has 350 miles on it now. I broke the a/c apart at the compressor and at the condensor to remove the engine, I put the engine back in and hooked all the a/c connection back up, and put the correct freon charge back in (1lb. 14oz. ). I nocticed then that it was taken a longer than usual time to put the freon back in. The compressor wasn't staying on but 5 or so seconds at a time. Drove the truck and the a/c wasn't cooling very good at all. Then stop working all together. When the compressor is on the a/c works great. Check for power at the compressor and there was none. Replaced pressure switch on the high pressure line, still no power to compressor. Replaced the a/c controls in the dash from a donor truck, still no power at compressor. Fuse is good in distribution box, swap a/c relay. Still no power. Really don't want to get raped by the dealer. What else can I check? My manual says to check a evaporator temp sensor but I think that involves removing the HVAC
. Please Help!
