Archived a/c condensor removal
Archived Truck in High Idle, and Dealer says VP44 Bad.
Archived p1689 Misfire and possible solution
Can anyone tell me how to diconnect the bottom tube coming from the a/c condensor. I can't figure out how to get that spring inside of the nipple out of the way to disconnect the two pieces of tubing:confused: . I have the new one ready to go in as soon as I can get past this little problem. Is there a special tool for this?? TIA!
Joe
Yes there is a special tool to release the spring. It looks kinda like a piece of tubing split to fit over the line. I have heard of releasing the spring with a thin piece of plastic or shimstock bent around the line. The tools are available at most auto parts stores and others. bg
THANKS
BG, Thanks for the info. I will try to locate the tool or I may even try the plastic trick. I tried cardboard, but it was not sturdy enough. Thanks again.
Joe
