I've been chasing an a/c coolant leak for quite a while now. Started spraying soapy water around after I charged it today and found the High pressure and Low pressure ports... where you tap into the system with gauges and to fill... are leaking. They have plastic caps on them but the caps have a weep hole in the center. Is there a way to cap these air tight?
