A/C Line Part number help . . . .
Adding Rear DVD to 2006 Megacab
Painted rear pumpkin again.
On my 2003 Quad cab 2500, what i believe to be the high pressure a/c line was rubbing against the auto transmission filler neck and rubbed a pin sized hole in it. Obviously I need to replace it. Does anyone have the part number for that hard line ?
Thanks, Rob
Rob, Rock Auto has the liquid line with oriface for about $ 48. 00 and also the discharge and suction line for about $ 105. 00. They also have pictures of each so you can compare.
2003 : DODGE : RAM 2500 PICKUP : 5. 9L 359 cubic inch L6 DIESEL FI Turbo (6) OHV : Heat & Air Conditioning : A/C Refrigerant Hose Price Core Total Add to Cart
FOUR SEASONS Part # 56822
Liquid Line w/ Orifice Tube
More Info
$47. 79 $0. 00 $47. 79
FOUR SEASONS Part # 56817
Discharge and Suction Line
More Info
$104. 79 $0. 00 $104. 79
Please check notes in each part listing to ensure the A/C Refrigerant Hose is correct for your 2003 DODGE RAM 2500 PICKUP with a 5. 9L 359 DIESEL OHV engine. Special restrictions like "California only" or "with sport package" may indicate a A/C Refrigerant Hose fits only certain 2003 DODGE RAM 2500 PICKUP models.
Clicking a "More Info" link will display a picture and/or other details about that A/C Refrigerant Hose in a separate window (you may need to turn off your pop-up-blocking software for this to work).
After choosing a A/C Refrigerant Hose, click the "Add Part" button. Shipping costs will be shown on the Shopping Cart page. You may use your browser's Back button, or click on "Find More Parts", to find more Heat & Air Conditioning parts, other DODGE RAM 2500 PICKUP parts, or parts for a different vehicle. Please try our Interactive Catalog (click red Start button above) for faster searching. Both catalogs use the same shopping cart, so any auto parts you've already chosen for your 2003 DODGE will not be lost if you switch.
Thanks Tom . . . I'm really looking for the MOPAR part number, Im gojng to order it from the local dealership . . Id rather OEM parts when it comes to this stuff. Did u make to Spring Fling . . ?
Get me the last 8 of the vin and I will come up with a number for you in the morning.
High side line, please give it a second look and see if it goes from the dryer/accumulator to the expansion valve for example.
Let me know.
Mike
