Where is the relay located, trying to check if the clutch is getting voltage, checked the clutch and it rotates freely. Fuse is OK. A/C lite comes on & the Fan kicks up speed but no cold air. I found comments on the internet about several owners having the same issue and the cause was a bad TIPM. At least one was able to have it flashed and that fixed the A/C. How or where would or could you check for voltage going to the A/C?
