Bhale
The best way to do it is to pull the ,2 wire plug,that plugs into the low pressure switch ,on the black round tank,(Dryer)back by the fire wall ,passanger side,pull the plug off and take a jumper wire and jumper across the plug,if your clutch kicks in, your low on feon,if so charge it ,don't run it with the jumper wire in it,if your low on feon (134A) You will burn up your compressor, Big bucks,The high side should read 215 lbs pressure at 80 dgrees out side,your center vent shoul be around 15-25 degrees when fully charged ,Hope this helps!
