2nd Gen Non-Engine/Transmission a/c not working
Engine/Transmission (1998.5 - 2002) Turbo questions
scotty-u
HELP!!! Warm weather is here and her truck's a/c is not working. I have checked the fuses and relays (all are good) and have cheaked the wires to the a/c compressor. Last work done on the truck was to replace the VP and lift pump. Any ideas??
Check Freon level, check high pressure switch on compressor line. You can unplug and cross leads with a piece of wire. Mine went out twice. Also check low pressure switch on dryer.
Rick
Is it just blowing warm or not coming on at all? On my 95 I need to add R-134 Refridgerant aprox every other summer as I must hav a very very slow leak.
Last summer mine quit while on vacation in Denver at 110+. The metal strap on the the clutch on the compressor actually tore so it couldnt engage. Check that the insides of the pully are turning and then the high/low pressure switches and freon. My buddies low pressurer connector corroded and just needed cleaned.
