A/C problem
wipers & cruise dont work right
Dashlights-odometer, tow haul, 4x4 lights don't work.
My 2006 Rams A/C quit. it has a full charge however there is no power to the compressor. The fuse is good. Any suggestions?
puller
puller
DIY and handy with DMM or 12V test light?
http://www.rambodybuilder.com/2006/docs/wd/dr/wiringdiagrams/8w42airconditioning.pdf
Referring to diagram 8W-42-6:
Engine idling with A/C ON:
Check for A/C CLUTCH CONTROL OUTPUT (battery voltage) on the DB/YL wire behind TIPM.
IF NO, then check for A/C CLUTCH CONTROL (Grounding signal from ECM) on the LB/OR wire.
If you have the grounding signal and have no CONTROL OUTPUT then TIPM is defective.
If you don't have the grounding signal then the issue is on ECM or before ECM.
I finally got to a .dealer and the compressor is bad. It was replaced last September and the whole job was covered under Dodge warranty. They also did the air bag recall at the same time.
puller
