On my trip to the coast last week, I had an A/C problem pop up. On the way down, the longer it was on, the warmer it got. To me, this means it was low on Freon. By the time we had gotten to Hatteras, it had frozen up. I left the truck running while we went in to get a slip for the boat and when I came back out, there was a big puddle of water under the truck in the area of the evaporator and the A/C was no longer working. Again, I figured it was low on freon and had frozen up. I hooked the gauges up to it the other day and tried to charge the system. While I was charging it, it seemed as though it was building up too much pressure and was "poping off" at the compressor? Is there a high pressure pop off valve on these compressors? Anyway, it is cooling again but the low side pressure is still not where it's suppose to be. Seems as though it is cycling on and off. Is this normal for this system? Does this thing have an expansion valve or orfice tube to meter refrigerent? And no, I didn't check the high side yet. Guess I should though. That'll tell me whether there is a restriction in the system or not. Any other thoughts on this from you experienced "frig" guys? See Ya!... ... ... ... . Racer
Ken-1993 W350, Cummins TD, 5 Speed, 4X4, Club Cab, LE, K&N, Straight Pipe, 4:10s.
http://users. lynchburg.net/ken0069
