Driving down the road my A/C blows 39-40°F out of the center vent with the return switch on. However if I sit at a light for even a short amount of time it will climb all the way up to 55-60°F. I have checked and the anti-freeze is at the proper level and concentration. The engine temp. is running normal while sitting (155-170°F) It started doing this last Spring and I thought it was due to a leaking head gasket. However, the head gasket has been repaired and the problem still exists. I've even checked the engine fan and it seems to still be properly dampened. Also the blades on the fan are clean, so there's been no leaking silicone from the clutch.
