A cam plate, or injectors??
Should I ARBITRATE
Happy Easter
I got my refund check back, and want your opinions on what should be first.
I'm kind of leaning towards the 370 injectors (dont want to remove the seal on my pump quite yet) plus, I'd like to do the cam plate when I do the governor and AFC springs all at once.
I dont want to do my cluch yet, would the stock cluch hold? I do not abuse it, so I wouldnt think it's worn.
How will the smoke be? What adjustments would be necessary? How much extra power should I expect? It presently runs fine, but should I re time it?
OR should I just get a 280hp cam plate?
I will be towing this summer. 24' TT, about 5000 lbs. A few thousand miles tops. Would any of these mods cause consearn of my EGT? I have gauges.
Thanks.
Eric
BTW the master plan, sometime down the road, is a cam plate, AFC and gov springs, and 370 injectors. I'm told I can get away w/o the 16 cm turbo with this combo. I realise a cluch would be necessary with this setup.
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 265 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
Patriot, I dont have the injectors but was extremely satisfied with the 280 hp plate from tst. Extra hp and torque blew my little mind. They also included a turbo waste gate. I'm not real sure what it did but as far as I could understand it adjusted when the turbo kicks in and when it shuts down. Havent needed new clutch. Pulled 10k pounds a couple of months ago and handled it with ease. Even through the hilly portion of eastern KY. Good luck.
96 Ram 2500 4x4 cc, 130,000 miles and counting, TST 280HP,K&N,Cat&muffler tag team fought w/torch, torch won.
Patriot:
Like "Nate" I think you would be happy
with the TST 280 plate too! I would try
that first in light of what you said
about your clutch.
I am not sure about running the 370's
with the "215 pump. " Joe Donnelly or
Piers can tell you though. When I did
my "modifications" I had the governor
spring, AFC spring kit, pump
"recalibrations" AND the 370's all
done together. Shortly thereafter my
automatic transmission had to be
replaced.
The 370's are going to give you more
smoke. Mine "clears out" at constant
speeds but if I "nail it" I will "fog
it up" pretty good. The EGT's can also
reach 1400 degrees if you are not careful.
However, I still have the stock HX-35/12
but am getting ready to go to the HX-40/16.
For right now I think that 280 plate
would be your best option.
Take care!
John_P
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
Injectors
95' 2500 5spd, 2wd reg cab 131,000
TST #4 plate kit, 370 Diamond B injectors, Afc spring kit, Gov. spring kit,TST's fuel pressure adapter and 2 guage pillar mount, SPA EGT/Boost guage. Joe D's Sachs clutch is in.
K&N Re-0880 & Prefilter. Cup Smoothie.
To be installed: MagHytec, 16cm2 Housing from Sportbike(thanks). Royal Purple oil, Finger Touch drain plug.
