a/cC water leak inside coach
Tekonsha Prodigy brake control
Stable Lift system for slide ins
Anybody ever have an a/c water leak inside the coach? Never had it with my old rv. Is this somehow related to the ducted system? Thanks , Jim.
I had one in both my RV's and it was simply that the AC was not tightened enough. remove the cover and tighten it down a bit but not to much. There is a big thick rubber gasket between the AC and the roof and it settles in.
szumigalas
There were some Dometic ACs that devoped cracks in the plastic drain pan under the ac unit. If tightening does'nt stop the leak have a rv repair plce look at it. It should be covered under your warrantee.
George
Thanks for the info. this is my 3rd a/c unit and the dealer said they found something else and it should be OK now. Weather is cold now and I won't have a chance to try it until Florida. Jim
