Well, my saga of getting a new NV4500 transmission from Quad 4X4 with the Torque King main shaft is almost over. I hope to pick up my truck early next week. (would have been done today, but I thought I ordered the new gear shifter for the transmission, but didn't and the 1997 shifter does not work with the new NV4500 transmission).
Anyway, the shop doing the work, when puting in Q4X4's TK pilot bearing, reviewd my SB Con OFE clutch and strongly recommended I put in a new clutch. Now ... the clutch lining was fine, but the hub is where the problems all lie. When I stoped by Blue Chip Diesel (southern NH) tonight, I got a good look at my clutch hub and saw how the springs have bottomed out and pounded the hub rivits (holding the two sides of the hub apart) to half their diameter!!!!
Please bear with me, I'm not a machanic, but, the inner portion of the hub that holds the springs in place pound the rivits all away around the hub. I probably was only a few thousand miles away from a complete hub failure!
I am having a new 6-speed Luk clutch installed ... very, very heavy duty where the inner disk that holds the springs is away from the rivits and has more and thicker springs to hold the shock.
I was very supprised at the design of the SB clutch friction disk setup. I can't believe that they have not relized this as a potential failure point.
I wish I had pictures of this to make it clear, but would like to inform anyone with this clutch that the next time you have to remove the transmission, inspect your clutch closely.
Its not like I have crazy power in the truck or beat the hell out of it, (just occationally), but was not pleased to see how this happened and how it could easly be avoided in their design.
Just an FYI.
Just an FYI.
