Details here: TDR Privileges
I use to run a A. D. D. all it really does is clip the voltage to the map sensor which prevents a fault code and your injector pump from defueling if your running to much boost. (Over 20 lbs or so. ) The newer boost boxes already have this built in. I was running an older dyno resources box with a modified wastegate so I needed it. Hope this helps...
