Hey Guys and Gals!
Now that winter is approaching there have been/will be a number of posts about winterizing our RV’s. I have a different method of getting the water out of my ’98 HH II water lines.
One day I was thinking (that is dangerous sometimes I know!) about "blowing" the water out. All of the faucets are above the level of the city water connection. That means that-
A, You are blowing some of the water up hill against gravity.
B, If you don’t have an “oil less air compressor” there is the chance of contaminating the water lines with oily vapor from worn air compressor rings.
C, I don't have a "clip on" air hose chuck. This requires that my wife
has to hold the air chuck on the blow out fitting.
Why not VACUUM the water out and let gravity assist you? I have been
using this method for so many years now that I don't remember how long
A short piece of 5/8" auto heater hose will just slip over the ½" PEX
drain lines. A trip to my local hardware store provided the PVC fittings to fabricate an adapter to adapt the heater hose to my wet/dry shop vacuum hose.
1, Drain the HWH.
2, Replace the HWH drain plug, verify that the HWH inlet, outlet and
by-pass valves are open. That way you will be pulling a vacuum on
both the hot and cold water headers at the sane time.
3, Connect the shop vac. to one of the drain lines, open the drain
valve and turn on the vac.
4, Go through the RV (the big lead weight with the aerodynamics of
a barn door, LOL!) opening and closing each of the Hot and Cold water
valves at each of the faucets and the toilet. Run the water pump for
a short time to clear it of water.
5, Close that drain valve, shift the shop vac. to the other drain line.
6, Repeat steps #3 &4.
7, Don’t forget to put about a cup of RV anti-freeze in each of the “P” traps.
When finished I will have normally have about a half of gallon of water in the shop vac.
To facilitate the drying of the HWH I then remove the HWH drain plug.
After losing a water pump a few years ago (I still think that either the suction/discharge check valve was just stuck) I will pump about a cup of RV anti-freeze into the pump to protect it.
This may not be for everybody but it works for me.
Richard
1, Drain the HWH.
Richard
